Hi
This was originally posted on the Revit Structure forum. Mainly aimed at Autodesk, but you guys may have the answer or yet another workaround due to revit shortcomings.
There doesn't seem to be a Monolithic insitu concrete stair with the following parameters:-
25mm thick thread finish,
20mm thick riser finish,
50mm thick half landing finish,
100mm thick ground floor finish &
75mm thick first floor finish.
All this to be modelled in the standard way and not just drafted with detail lines etc.
Has any one accomplished this yet.
Its about time this was available from the Revit metric library with all these parameters.
Hope this subject doesn't remain silent with you guys to.
