How to get the image on the left to look like the image on the right? Underside of stairs-slab joint, and to make the connecting line dissapear.
Unfortunately, the Join Geometry tool does not work with Stairs. They don't join to other elements. One common solution is this: View > Edit Cut Profile > create (in two different sessions) the outlines shown in red in the illustration I am providing. After that, make the hatch pattern of the slab match that of the stairs.
This is a 2D solution, specific to the view. It won't have an effect in other views, and it won't produce a change in the actual model.
OK, thanks, problem solved, maybe in the next release of revit they should add the option to join stairs to slabs
i have the same issue , can you tell me how to fix this in the model not only in 2d view !
I believe this problem has been solved with Revit 2014.
see here:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-E36AE889-D507-4288-90BE-FCE2F120C2B6
Take a look at Precast Stairs.
Hi all, this is an issue not very well solved in Revit yet, but with the monolithic stair by components I can ad a landing to the last riser and get the solution for the landing and stair. See the attached image.
I hope this will be usefull to you.
Alex
Hows this looking 10/6yrs on? My Stairs floor joints look like a dog's breakfast.
I really dont like sending drawings that look like this out of the office....
@Seychellian wrote:Hows this looking 10/6yrs on? My Stairs floor joints look like a dog's breakfast.
Clean connections between all the elements. Like this......
