Monochrome option in the Revit,
2 REPLIES 2
JamaL9722060
1561 Views, 2 Replies
I’m wondering if there is a monochrome option in the Revit such that in case the drawing that contains different colors (attached) can be printed all in black with the same behavior as in monochrome (attached).
Thank you
Best
Jamal
Jamal Numan
2 REPLIES 2
joaorcunha
in reply to: JamaL9722060
Have you tried turning on grayscale appearance in Print Settings Dialog? IT usually is set up to colors, but can be switched to grayscale or monochrome.
João.
Crazy for BIM since 2007...
JamaL9722060
in reply to: joaorcunha
Many thanks João for the help, it works fine
Best
Jamal
Jamal Numan
