I want to create a modular Dry Wall, with a u profile running on its four side. So far İ am able to make a wall with a standard panel width of 1 Meter but couldnot able to place a U-profile across its four sides. In addition at time their is a possbıliıty that U-profile spans over three panels instead of just one. I have attached two files one is what i have developed so far and second images contains what i want to achieve. Plz help.
Solved by constantin.stroescu. Go to Solution.
I think that : Using Curtain Wall with infilled panels - Basic Wall and mullions with the desired profil will slove the problem.....
Your Name
Thanks , i am trying to make a custom mullion but facing the problem.The selected mullion profile either contains more that one profile loop or an open profile loop and cannot be used . Valid prfiles can oly have a single continuous cloase profile loop
You have to make a closed profile as in real life.
In real life there is no object without thicknes.....you can use an offset of 1mm for instance and this use a closed profile...something like in my image ....
Your Name
I think i am almost their. Is their any way of rotating the direction of Mullion as it is isntalled coorectly on te top however the isntallation direction on the side is opposite.
Your Name
