I'm using Revit 2012. When i go into editing mode i have to cycle thru the modify ribbon to get to the correct tab to do and complete my edit. It wasn't like this before, and I don't know how it changed. How do i fix this problem?
I've tried reinstaling the latest .Net framework and deleting the UIState.dat file but neither of those fixed the problem
Solved by cbcarch. Go to Solution.
Actually, installing the latest .net version will cause issues with Revit 2012. You may need an earlier version; 4.0 or earlier.
Also take a look here--seems like a better solution:
