Revit Architecture
New Member
plywood
Message 1 of 4 (167 Views)
modify tab problem
167 Views, 3 Replies
03-10-2014 10:51 AM
I'm using Revit 2012. When i go into editing mode i have to cycle thru the modify ribbon to get to the correct tab to do and complete my edit. It wasn't like this before, and I don't know how it changed. How do i fix this problem?
I've tried reinstaling the latest .Net framework and deleting the UIState.dat file but neither of those fixed the problem
Actually, installing the latest .net version will cause issues with Revit 2012. You may need an earlier version; 4.0 or earlier.
cbcarch
Message 2 of 4 (164 Views)
Re: modify tab problem
03-10-2014 10:56 AM in reply to: plywood
Cliff B. Collins
Registered Architect/BIM Specialist
Autodesk Revit Expert Elite
New Member
plywood
Message 3 of 4 (152 Views)
03-10-2014 11:14 AM in reply to: cbcarch
Thanks cbcarch!
I uninstalled .net and reinstalled version 4.0 and that fixed the problem.
cbcarch
Message 4 of 4 (130 Views)
03-10-2014 12:13 PM in reply to: plywood
Also take a look here--seems like a better solution:
http://www.revitforum.org/architecture-general-revit-questions/18832-problems-modify-tab-2.html#post...
Cliff B. Collins
