modify tab problem
3 REPLIES 3
plywood
597 Views, 3 Replies
modify tab problem
I'm using Revit 2012. When i go into editing mode i have to cycle thru the modify ribbon to get to the correct tab to do and complete my edit. It wasn't like this before, and I don't know how it changed. How do i fix this problem?
I've tried reinstaling the latest .Net framework and deleting the UIState.dat file but neither of those fixed the problem
3 REPLIES 3
cbcarch
in reply to: plywood
Actually, installing the latest .net version will cause issues with Revit 2012. You may need an earlier version; 4.0 or earlier.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
plywood
in reply to: cbcarch
Thanks cbcarch!
I uninstalled .net and reinstalled version 4.0 and that fixed the problem.
cbcarch
Also take a look here--seems like a better solution:
http://www.revitforum.org/architecture-general-revit-questions/18832-problems-modify-tab-2.html#post...
Cliff B. Collins
