Revit Architecture
Valued Contributor
Bill.Knittle
Message 1 of 4 (446 Views)
Modify tab out of Place
446 Views, 3 Replies
08-12-2010 09:59 PM
Last night I was editing an In-Place family and for some reason, Revit did not exit the In-Place Editor properly. The Modify tab was kicked all the way to the left on the ribbon to precede the Home tab. Is there a way to reset the ribbon to its default state because, the contextual tabs react to the new location of the Modify tab? I have attached an image.
I am using a M6400 Dell Precison Laptop with Win 7 64 and SP1 has been installed to Revit Architecture
257i7D64486D505FBFBF.
Ryan,
Thanks for the tips. Ctrl+Drag worked great!!!
Employee
ryan.duell
Message 2 of 4 (436 Views)
Re: Modify tab out of Place
08-13-2010 05:34 AM in reply to: Bill.Knittle
There are 2 approaches to resolve this:
1.  You can rearrange tabs while holding the CTRL key:
2.  You can reset the UI back to default [which will reset any QAT or ribbon customization]:
Hope this helps!
http://revitclinic.typepad.com/my_weblog/2010/02/ui-tips.html
http://usa.autodesk.com/getdoc/id=TS14880949
Hope this helps!
Ryan Duell
Revit Clinic
@revitclinic
Valued Contributor
Bill.Knittle
Message 3 of 4 (424 Views)
08-13-2010 07:42 AM in reply to: Bill.Knittle
Ryan,
Active Member
miss_metz
Message 4 of 4 (167 Views)
01-28-2012 03:55 AM in reply to: ryan.duell
hi there, the link doesn't work anymore - do you have another link to the same, that works?
thank you...
