I have 2 names in a Room Finish Schedule that shouldn’t be there. I think they are there because I copy and pasted something from one project to another. In any case, these 2 names appear in the schedule but NOT on the plan. How do I delete them from the schedule please?
Solved by VWD-MLM. Go to Solution.
Pick on the room Name or Number in the Schedule, Go to the Top and Select the delete button.......I usually verify that i don't acctuall need the room(s) 1st by checking to see if the "Highlight" Button stays greyed out...if it does, that it doesn't physically exist and can be deleted. By Checking to see if it "Highlights" in the plan view, you verify that it wasn't inadvertantely "hidden By Element" in the view(s).
HTH.
Mike
