Modifiers Layer DWG
2 REPLIES 2
GHASEM_ARIYANI
2065 Views, 2 Replies
Modifiers Layer DWG
Hi
Can anyone give more explanation about setting Revit to DWG?
For example, How to use the editor window,And at what time should be set?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
CoreyDaun
in reply to: GHASEM_ARIYANI
The Layer Modifiers are used to create new Layers based on each element's information according to the Modifiers that are chosen.
As an example, say you have a Project with three Walls - one new, one existing, and one demo. Our View is set to New Construction Phase, and 'Show All' as the Phase Filter. We want to export this to DWG format using the 'Export Layer Options:' set to "Export Category Properties BYLAYER and overrides BYENTITY" (which is default). Currently, if we export this View, all three Walls will be exported onto the same Layer; whatever is designated for Walls in the Export Settings (default "A-WALL"). The difference in their Phases will be applied to each entity in AutoCAD by way of Color and/or Linetype Override. So...
           AutoCAD Entities
In Revit Layer Color Linetype
New Wall A-WALL ByLayer Continuous
Existing Wall A-WALL Color 8 Continuous
Demo Wall A-WALL White ByLayer
This can be quite cumbersome to deal with in AutoCAD since all of the Walls are on the same Layer. Now, say we added the "{Phase Status}" Layer Modifier (with a "-" separator) to the Walls in Revit's Export Settings. If you scroll down to the Modifiers and expand "{Phase Status}" you will see that the default values for "Demolished" is "D", "Existing" is "E", etc. This value will be added to the entities Layer Name in AutoCAD, hence separating them into different Layers according to their {Phase Status}. So the same three Walls export to AutoCAD will look like...
           AutoCAD Entities
New Wall A-WALL ByLayer ByLayer
Existing Wall A-WALL-E Color 8 ByLayer
Demo Wall A-WALL-D White ByLayer
Notice that there are all on different Layers, now?
If you search this forum, you will find more information on Layer Modifiers, and perhaps the best way to learn is to experiment with them. This is a pretty brief run-through, so don't hesitate to ask if you have any questions. Hope this helps.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
GHASEM_ARIYANI
in reply to: CoreyDaun
Hi CADastrophe
Thank you so much, you are very nice and patiently explained.
I According your explanation, I would practice.
