model text rotation
4 REPLIES 4
3559 Views, 4 Replies
model text rotation
I am using the model text in my design as support underneath the building and want to change it from being horizontal to vertical....
Any suggestions
Tags (1)
4 REPLIES 4
With a work plane on the back of the model text, looking at
it from the front, rotate it.
I can't get that to work. it only rotates it in plan.
I want to rotate it 90 degrees in elevation
In the plan view, draw a reference plane where you want to
be looking down on that model text. Where the plane will be
on the back of that text. Select that new reference plane and
go to the instance properties and give that plane a "name".
Then go to an elevation view that is perpendicular to that
plane and put in your model text on the new plane. From
there you will be able to rotate it.
Thanks for your help. It has worked!
