MODEL TEXT ON A WALL
5 REPLIES 5
5698 Views, 5 Replies
I have a small wall that i need to place model text (3d text) on. How do i
go about getting a working plane on the face of a wall???
John Gray
FYI Revit 8.1
5 REPLIES 5
Go to the elevation view, click the plane tool and pick, then pick the face of the wall(an edge that highlights the face)
Are you talking about using a "reference plane"??? if so do i draw it and
then rotate it or something, sry i don't understand......
John Gray
wrote in message news:5256302@discussion.autodesk.com...
SRobbins
Goto the Elevation view(or 3D view), Select the Plane tool. Its located in
the upper left, second menu icon bar down. In the next window select "Pick
a plane". Then you should be able to pick the face of the wall and write
your model text on it.
"John Gray" wrote in message
news:5256364@discussion.autodesk.com...
John Gray
OH That plane tool, lol.....thanks for the quick respnoce it worked
great........ I assume that once i place it and draw something on it, it
can not be deleted.
wrote in message news:5256510@discussion.autodesk.com...
John Gray
The object you draw on the plane can be deleted....the "plane" you pick is
really not an object...its just a representational plane in space, and
cannot be deleted...but really doesn't 'exist'.
news:5256504@discussion.autodesk.com...
can not be deleted.
John Gray
