To incorporate the company name to the building facade, I used the model text feature to add text in a family. I can see it in the 3D view of the building model but on the elevation sheet I only see the outline of the text. I would like it to be black filled otherwise it blends with the exterior finish and all the architectural annotation near it.
Does anyone have any idea?
Solved by constantin.stroescu. Go to Solution.
Assign a material to the model text, perhaps a solid black paint.
make an override by element or by caegory:
Constantin Stroescu
similar to other response, but use "cut patterns > foreground" so if you need to print with wire frame, the text stays solid.
For all views, change in visibility graphics instead of an override. use cut patterns
