Revit Architecture
Valued Contributor
kwihae
Message 1 of 3 (956 Views)
Model hatch direction
956 Views, 2 Replies
12-22-2011 06:22 AM
How do you change the direction of a model hatch that is seen in 3D view?
I want to change the pattern of wood planking that goes horizontally to go vertically (in plan view).
Thanks you!
Use the Tab key to select a line in the pattern, the use Rotate.
cheers
ccollins
Message 2 of 3 (943 Views)
Re: Model hatch direction
12-22-2011 08:11 AM in reply to: kwihae
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Employee
loboarch
Message 3 of 3 (943 Views)
You can modify the surface pattern of model componets in a number of ways.  Here is a link to the section of the wikihelp on controling the surface pattern of mopdel elements.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
