Good Job, Its great when people really know their technolgy. Definiently, you have to create custome profiles one for each side of the curtain wall. The tricky part for me is getting the corner profile exaclty were you needed it. But its a good stratagy.
Loading the profile is also a two step process. That requires you to create a new Type of mullion using the duplicate option and then changing the profile. with out that you can't find the new loaded profile.
Thanks for sharing.
Hector Camps
cniibu - don't see the 'vertical butt joint' toggle? is it there in 2014?
