Hi all,
For the past few weeks I've been working on Revit and there has been no problems. All of a sudden when I went to edit a family and add an extrusion, all the options that come up on the ribbon are missing. I've tried reinstalling, repairing and restarting everything but it doesn't seem to come back. I've read a bunch of articles on this problem but the articles are almost a year old.
Please see attached for a picture of the missing options.
Thank you!!!
Solved by alex60. Go to Solution.
I think the most common cause for this are the .net 4.5 (windows) libraries. Some versions of Revit have been receiving updates others have had hot fixes for these issues.
So probably the easiest is to check if there are updates or hotfixes for your version (LINK).
Otherwise, if you know the date the problems started, you could return to a restore point before that date to see if that fixes the problems.
Louis
Please mention Revit version, especially when uploading Revit files.
hi, which version of revit you are using?
Hi all, the problem is that Windows Updates are installing the .NET 4.5 automatically, so you have to check out the programs and features in Control Panels to see this issue. Delete 4.5 and reinstall the 4.0
I hope this will be helpfull, Thanks, alex
Update Release 3 for Revit 2013 fixes the contextual ribbon problem that occurs when .NET 4.5 is installed. Links to the commercial updates can be found in this blog article. I am not certain if these can be applied to the student version, or if the student download site has equivalent versions.
