I just downloaded the Trial of REVIT LT 2014, and cannot find any template files. I've tried to find them elsewhere but after two days of looking can't. I am trying to follow along with the Learning Autodesk Revit LT 2014 Essentials book as well as the tutorials on YouTube but all require the "Architectural Template" that I don't have. Is there somewhere that I can download the missing file? I would just keep going but I can't even get the level system to work in a basic "New Project" file.
Thanks for your help
Solved by scott_d_davis. Go to Solution.
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-851D6C9F-3E00-460D-B49E-341C22D3B9B5
Hey man, did u solve the problem? i read the solution but still cant solve it? can u give me more details if u solved this. thank you very much.
i still need help getting the families and templates in. i follow your instructions but im not sure what i should be seeing to select to upload into revit. i choose us imperial and us metric and click add content then just a regular window comes up asking me where i want to put the file. i don't know where i should be putting the file. please help!
The missing Templates problem for Revit 2014 can be fixed if you just Reinstall the program.
Steps:
1. Star-up button --> "Control Panel"
2. Click "Programs and Features" --> Aurodesk Revit 2014
3. Click "Uninstall/Change" or double-click on the "Aurodesk Revit 2014" text
4. A Window will pop-up --> click on the "Repair or Reinstall" button
5. Check the "Repair" bullet --> Click Next.
6. Once finished --> Startup Revit 2014
7. Click "New" from the menu (top left icon)--> Click Project
8. Now you should have Templates --> Choose your template, I usually choose Architectural
GOOD LUCK! , Hope it helped
Same thing happened to me, I have done everything everybody said and nothing, I just cannot get any templates.
