Missing template files in REVIT LT 2014
6 REPLIES 6
18254 Views, 6 Replies
I just downloaded the Trial of REVIT LT 2014, and cannot find any template files.  I've tried to find them elsewhere but after two days of looking can't.  I am trying to follow along with the Learning Autodesk Revit LT 2014 Essentials book as well as the tutorials on YouTube but all require the "Architectural Template" that I don't have.  Is there somewhere that I can download the missing file?  I would just keep going but I can't even get the level system to work in a basic "New Project" file.
Thanks for your help
6 REPLIES 6
scott_d_davis
From help.autodesk.com
"How Do I Add or Remove Revit Content?"
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-851D6C9F-3E00-460D-B49E-341C22D3B9B5
Scott D Davis
Sr AEC Technical Specialist
Hey man, did u solve the problem? i read the solution but still cant solve it? can u give me more details if u solved this. thank you very much.
in reply to: scott_d_davis
i still need help getting the families and templates in. i follow your instructions but im not sure what i should be seeing to select to upload into revit.  i choose us imperial and us metric and click add content then just a regular window comes up asking me where i want to put the file.  i don't know where i should be putting the file. please help!
same here.. so frustrating. their instructions dont help at all.
 The missing Templates problem for Revit 2014 can be fixed if you just Reinstall the program.
Steps:
1. Star-up button --> "Control Panel"
2. Click "Programs and Features" --> Aurodesk Revit 2014
3. Click "Uninstall/Change" or double-click on the "Aurodesk Revit 2014" text
4. A Window will pop-up --> click on the "Repair or Reinstall" button
5. Check the "Repair" bullet --> Click Next.
6. Once finished --> Startup Revit 2014
7. Click "New" from the menu (top left icon)--> Click Project
8. Now you should have Templates --> Choose your template, I usually choose Architectural
GOOD LUCK! , Hope it helped
Same thing happened to me, I have done everything everybody said and nothing, I just cannot get any templates.
