I'm looking into conceptual adaptive massing but in my metric templates folder (conceptual mass folder) I only have metric mass.rft. I don't have the Adaptive Component.rft?
Can this be downloaded from somewhere?
Thank you,
Mark
Solved by ryan.duell. Go to Solution.
You can download the template file at the following link:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14973523
The metric “Metric Adaptive Component.rft” is part of the “IntMetTempl.cab” cabinet file.
Thank you,
Thanks for the link. I now have the correct templates in place.
In trying to get to the bottom of this, I discovered that IT had configured Revit 2011 to look at the older 2010 templates! So it was on our servers all along, Revit was just looking in the wrong place.
Thank you again.
Mark
hi
the link to the site informs the page is not found or its been moved. is there any other site in which i can download the .rft file?
regards
abby
Which version of Revit are you looking to download content for? The more recent versions can add \ remove features from the control panel. Such as this example:
Additional information can be located here as well:
Revit 2015 | How do I add or remove content?
Let us know if this helps, thanks!
Im also lookinf for this family template, im using Revit 2015.
Just upgraded the Content Libraries from Control Panel but still dont have the Metric Adaptive Component.rft
Any direct link?
Maybe you're looking for the wrong name? In my Revit 2015 (imperial library), the name of that template is "Generic Model Adaptive", not "Adaptive Component". Or you can use the Revit 2014 version of this template, and use that as a start point. It's the same anyway.
Hi Alfredo,
Was because a videotutorial that was using Revit 2011, seems it no longer exists.
As you mentioned, Metric Model Adaptive worked pretty well (Metric library in my case)
Thanks!
Jenner M.
Missing Generic Model Pattern Based.rft File in my folder
can you tell me where to go and download the file?
Or some one and email me the file at ray@rghva.com
Great help
Hi, please where do I download "metric adaptive component", "metric pattern based", and "metric mass"template for revit 2016 from, or will the ones for 2015 work on 2016? Thank you.
