I have created a door family that has a concrete fill that replaces the insulation in an insulated precast wall. When I cut a section through the jambs looking down it looks correct but when the section is looking up the concrete fill pattern is not visible.
How do I fix this? I would typically cut my sections looking up so that the exterior face is down in the view as it will be cast.
I have tried to reproduce this but could not on my end; I'm sure I am just not setting it up the same way you are. Do you have a small sample file or family you could attach to help illustrate what you're seeing?
Thanks Hayden, I got it and am looking now...
Hey Hayden,
I am going to set up a case for this so we can look into it further. I'll send you an email from it shortly.
