Hi, I am using 2014 Revit and have some problem with the exported AutoCAD layers from Revit.
My project has 3 levels and I exported the floor plans from Revit.
Ground level and third level have all the elements like shown Revit, but the second floor plan doesn't show certain catagory items like columns. I already tried to create new level for the second floor plan, but the exported result is the same. I am not sure if there is any setting to control the layer visibility when it is being exported. Please answer me if you already went through this situation or got an answer. Thank you so much.
In Application Menu (R) > Export > Options > Export Setups DWG/DXF > Layers :
there are two predefined layers for Columns:
A-COLS - for Architectural Columns ( AIA notation)
and
S-COLS - for Structural Columns (AIA notation)
see to be both active (+)
Constantin Stroescu
