Missing Elements in Linked Models
2 REPLIES 2
1600 Views, 2 Replies
We have a structural model linked into our building model for a project with about 10 people working on it.  Periodically, some users cannot see all of the elements in the linked structural model.  We have tried/checked the following:
Checking Visibility/Graphics (Worksets, Links, Categories)
Checking Reveal Hidden
Opening/Closing Worksets
Unloading and reloading the Links
Opening different Views to find the Elements
We are unable to resolve the problems through the methods above.  Oddly, when a different user opens the view the elements are displayed.  Or, if we override via Visibility/Graphics to the linked model settings the elements are displayed.  In this second sceanario the only way to control the graphics is by changing them in the linked model.
Nethier workaround is efficient or productive.  Any thoughts appreciated.
2 REPLIES 2
Update: We are closer to solving the problem, we think.
For some reason, the workset visibility is getting changed in the linked model on a user by user basis.  Via Visibility/Graphics, we can override the linked model Visibility/Graphics setttings to custom and turn on the worksets.  Again, this is user by user.  A different user can open the same view and not have this problem.
Is there anyway to globally overide the visibilty of worksets in a linked model?
Via Manage Links and Manage Worksets, the central model has all of the Worksets opened.
fernanda.firman
Have you ever resolved the issue?
You can try using view templates.
Create a new view template, set the V/G and apply to the views.
Hope that helps.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
