Missing (Draw) panel
8 REPLIES 8
Message 1 of 9
jz4all
4025 Views, 8 Replies
Hi
I don't have long experience in Revit. I downloaded a Revit file from internet containing a drawing. When I tried to draw a wall, door , reference line ...etc. I noticed that (Draw) panel is missing? How can I get it back?
For information, this panel exists in the Revit Editor when I try do draw my own drawing or a new drawing.
8 REPLIES 8
Message 2 of 9
LisaDrago
in reply to: jz4all
Hello - Can you post an image of what you are seeing?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Message 3 of 9
jz4all
in reply to: jz4all
Hi
thanks for your response. I attach hier images to explain the problem. But it seems that the problem is solved after restarting Revit and after restarting my PC. But how that happened, and how it solved? I don't know!!
If you know any explanation for what happened, I'll be greatful, that will help me to solve such problem in the future.
Thanks again
Message 4 of 9
David_W_Koch
in reply to: jz4all
Make sure you have the latest service pack installed. If you machine has had .Net upgraded to 4.5 (which Revit 2014 and other more recent programs require), there will be issues with the contextual ribbons/panels that can be resolved by installing the latest service pack.
From the images you posted, you appear to have the "one box" version of Revit (Arch, Structure & MEP in one program), so you will want this version of SP3:
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/revit-2013-upd...
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 5 of 9
jz4all
in reply to: LisaDrago
you mentioned before an interesting point. It's about (cycling through the ribbon )? but how? I tried to klick the last title of the ribbon or press and drag it but nothing changed.
As you see in my attached pictures there is no such possibility, like arrow for instance, to do such action. Can you give more explanation? Here I am asking about the principal if I face such problem.
thanks
Message 6 of 9
Alisder.Brown
in reply to: jz4all
See attached image to cycle through the ribbon states.
This method is only a temporary fix, as mentioned, you need to install the service pack to solve your issue.
Regards
Alisder Brown
Senior BIM Coordinator
Scotland, UK
Message 7 of 9
jz4all
in reply to: jz4all
Thanks for your kindly response.
I did already this kind of cycling.
the problem is already solved as I mentioned before. But I tried to inform if I face such problem in the future. And I'll install the service pack.
thanks again
Message 8 of 9
bryanlow
in reply to: jz4all
How to retrieve back the Draw Panel
Message 9 of 9
in reply to: bryanlow
There is no Draw panel.  You are looking at an outdated tutorial.  Use panels provided in recent Revit versions.
