Hi
I don't have long experience in Revit. I downloaded a Revit file from internet containing a drawing. When I tried to draw a wall, door , reference line ...etc. I noticed that (Draw) panel is missing? How can I get it back?
For information, this panel exists in the Revit Editor when I try do draw my own drawing or a new drawing.
Solved by David_W_Koch. Go to Solution.
Hello - Can you post an image of what you are seeing?
LD
Hi
thanks for your response. I attach hier images to explain the problem. But it seems that the problem is solved after restarting Revit and after restarting my PC. But how that happened, and how it solved? I don't know!!
If you know any explanation for what happened, I'll be greatful, that will help me to solve such problem in the future.
Thanks again
you mentioned before an interesting point. It's about (cycling through the ribbon )? but how? I tried to klick the last title of the ribbon or press and drag it but nothing changed.
As you see in my attached pictures there is no such possibility, like arrow for instance, to do such action. Can you give more explanation? Here I am asking about the principal if I face such problem.
thanks
See attached image to cycle through the ribbon states.
This method is only a temporary fix, as mentioned, you need to install the service pack to solve your issue.
Regards
Thanks for your kindly response.
I did already this kind of cycling.
the problem is already solved as I mentioned before. But I tried to inform if I face such problem in the future. And I'll install the service pack.
thanks again
