Mirroring
7 REPLIES 7
Message 1 of 8
318 Views, 7 Replies
Mirroring
I am having a problem with mirroring. When I mirror a stair the hand rails detach from the staim and mirror 90 degrees from the stir horizontally but the same stair will mirror properly if I mirror vertically. Anyone else having this problem? Revit 6.1 Thanks Doug
7 REPLIES 7
Message 2 of 8
Try grouping the stair and rail first? I'm flipping stairs with no problem here, but I have them grouped with some associated details. "Doug" wrote in message news:405aed57_1@newsprd01... > I am having a problem with mirroring. When I mirror a stair the hand rails > detach from the staim and mirror 90 degrees from the stir horizontally but > the same stair will mirror properly if I mirror vertically. > > Anyone else having this problem? > > Revit 6.1 > > Thanks > > Doug > >
Message 3 of 8
Grouping worked to keep the railing with the stair when mirrored, but I still got a duplicate set of straight horizontal rails at 90 degrees to the stair I mirrored. The good news is that deleting this bonus set of railings doesn't seem to affect either the mirrored or original stair.
Message 4 of 8
Doug wrote: > I am having a problem with mirroring. When I mirror a stair the hand rails > detach from the staim and mirror 90 degrees from the stir horizontally but > the same stair will mirror properly if I mirror vertically. > > Anyone else having this problem? I've run into this too. Seems a bug. Grouping them helps, but you still get an 'extra' railing to delete. -- Jeffrey McGrew Application Specialist BSD AEC Technologies, a division of ID8 Media Inc. (415) 593-6000 x 129 (415) 593-3333 Fax (415) 505-4689 Cell www.aectech.com www.id8media.com
Message 5 of 8
Bud Hester
I'm having the same problem. New to Revit. Thought I was doing something wrong. Sounds like something we will just have to work around, huh?
Message 6 of 8
hi, I faced the same issue, but it seems grouping them solves the issue. After grouping i did't had to delete any extra railing. FYI... Hope in future releases we dont need to trick the revit this way... Eat Revit, Drink Revit, Sleep Revit.... "Doug" wrote in message news:405aed57_1@newsprd01... > I am having a problem with mirroring. When I mirror a stair the hand rails > detach from the staim and mirror 90 degrees from the stir horizontally but > the same stair will mirror properly if I mirror vertically. > > Anyone else having this problem? > > Revit 6.1 > > Thanks > > Doug > >
Message 7 of 8
shane.trammell
i am having this same problem. i am new to revit and cad stuff so how do i go about grouping the railing and the stairs?
Message 8 of 8
shane.trammell
nevermind, i got it.
