I have looked everywhere for an answer. Why does Revit insist on changing the justification of text after mirroring?!? Text originally left justified will automatically be right justified if mirrored. I understand Revit's trying to "help" by mirroring/converting the justification, but is there a work around to getting this function to be less painful if you don't need this to happen? If there are 50 notes in a detail to mirror and they all need to remain left justified after mirroring, I have found no quick way to change them than to go in one by one and re-justify them. Annoying.
Since there are no "Keep original Justification" or "Justify Multiple" buttons , does anyone have any suggestions in the mean time?
Thank you very much!
Solved by bearsley. Go to Solution.
here are 2 options depending on the end result you're after:
option 1: mirror the mirred text in the same place while it is still selected (if there are leaders they will be mirrored also)
option 2: select all mirrored text, then change justification in properties under "Horizontal Align"
happy reviting!
Brian Earsley
708.336.7083
BOOM! Bearsly, you're my new favorite person (for two reasons). Reason number 1, Option 2 was exactly what I was looking for!!! Option 1 wouldn't work for me because I still needed the leaders to point in the mirrored direction, but option 2 modified the text all at once just like I was hoping for.
Thank you so much for your help!
P.S. Reason number 2, I also tell people "Happy Reviting" everytime I end one of my posts in my Revit blog.
