Revit Architecture
Member
meg-m
Message 1 of 5 (604 Views)
Merging Curtain Wall Panels
604 Views, 4 Replies
11-28-2010 02:40 AM
Is there a function in revit to merge a number of curtain wall panels together into 1? All the panels I want to merge are adjacent to one another, seperated by grid lines.
Active Contributor
ghDH
Message 2 of 5 (565 Views)
Re: Merging Curtain Wall Panels
12-01-2010 01:38 PM in reply to: meg-m
no
New Member
mta315
Message 3 of 5 (326 Views)
10-04-2011 02:03 PM in reply to: ghDH
The user manual says there is, but doesn't say how.
ccollins
Message 4 of 5 (322 Views)
10-04-2011 02:20 PM in reply to: mta315
You must delete the curtain grids. (completely, including all segments.)
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Active Member
peter
Message 5 of 5 (172 Views)
11-29-2013 10:42 AM in reply to: meg-m
This is from the Autodesk website...
  1. Create the curtain wall panels.
  2. See Curtain Walls, Curtain Grids, and Mullions.
  3. Add curtain grids.
    See Creating Rectangular Curtain Walls.
  4. Select a curtain grid.
  5. Click Modify Curtain Wall Grids tabCurtain Grid panelAdd/Remove Segments.
  6. Click on a curtain grid segment to remove it.
    As you remove segments, adjacent panels join.
  7. Click in white space in the drawing area.
