Can we merge two or more than command in a single command in revit?
Can you elaborate a bit more on this - I am not sure what you are wanting to accomplish.
LD
For a example:
We will create a single command where two or more than two command execute at a time so that we will reduce our project time.
I have not heard of anywone before wanting to do this and I am not sure you can do this.
Each command has a certain process - I am not sure you can combine commands because of this...
I have a feeling this is somehting Autodesk needs to answer.
LD
If you want to create a string of commands, you'll have to learn how to use the API to develop your own tool. You cannot run a sequence of commands out of the box.
Here's my example. I want to set elevation mark (first command) for the ventilation duct and split it in the same point (second command). Is there any ideas how ot do it?
Evgeniy
Or for example create a section (1) and go to view (2). This will save 3 clicks (selection section, right click, go to view).
So if someone wants to create 10 sections in one go then he needs to close the section view every time before the next one? Great idea.
