When linking in a revit mep 2012 into an architectural model is there a way to change the colors of the mep elements (ie. ductwork, piping etc.) to black or even to grayscale?
Solved by CoreyDaun. Go to Solution.
Most of the time, the Ductwork, Piping, etc. is colored by System Overrides, which supersedes the normal V/G Overrides. I think your best method would be to create a View Filter that affects all of the Duct and Piping categories, assign no Filter Rules, and then this can be used to set all of those elements to black or whatever color you wish.
As I recall, you can highlight the entire Linked MEP model, right click--and then select Override Graphics in View and select Halftone, and select the color.
To do it "globally"--you could open the MEP file, go to Object Styles, and change everything to grey and/or halftone, then save/reload the Linked MEP model in your Arch. file.
@Anonymous wrote:"As I recall, you can highlight the entire Linked MEP model, right click--and then select Override Graphics in View and select Halftone, and select the color."
You can apply halftone to these categories by normal means, (through "V/G") by setting the categories or the entire link to halftone. I don't think that you can Override in View by Element, then entire thing, though.
@Anonymous wrote:"To do it "globally"--you could open the MEP file, go to Object Styles, and change everything to grey and/or halftone, then save/reload the Linked MEP model in your Arch. file."
The System Overrides will trump Object Styles as well. If you want to change the color within the MEP Model, one would have to go to Project Browser » Families » Duct Systems and go to each system's Type Properties » Graphic Overrides and click "Clear Overrides". The same must be done with Piping Systems.
I don't have Revit Architecture, so can someone verify if you can access "Duct Systems" in the Project Browser?
The only workaround we found (which is time-consuming, depending on the size of the model) is this:
Open the MEP model in Revit Architecture
Scroll down to Families in the Project Browser
Expand Duct Systems and/or Piping Systems
Double-click each system (i.e. Exhaust Air, Return Air, Supply Air) and click the Graphic Overrides parameter EDIT button
Change the Line Color to <No Override> (or whatever color desired)
Save, exit, and reload link in Revit Architecture
It's a small task for us, but our consultants find value in those elements changing colors when they are properly connected in the model. Hope this helps!
I have 2 separate linked models, Mech & Plumbing and am trying to distinguish between the Pipes/Ducts. The filter overrides all the objects in the model. i.e. all the Pipes in both links change color if I apply a filter to the view. Also tried to put the 2 models in separate worksets and use that as a parameter in the filter which did not help either.
Appreciate your help.
I found this option and it covers most elements of the linked MEP model by filter and changing color.
linked-file-revit-mep-has-colors.html
After 6 years to the previous post, it's strange that it still isn't easy within Revit
If you're still using Revit 2016, when this thread was created and that article that you posted were written, then nothing has changed. You just brought us on a ride in the Way Back Machine.
In Revit 2021 it's still the same.
I was looking for a solution and came at this topic, sounds like a bad ride then 😉
But what I really want is, just select/filter the linked model and change appearance. How hard could it be?
Do you have a problem creating filters?
Do you want them handed to you? Ask your BIM/CAD Manager.
