I am having trouble finding my MEASURE TOOL in revit 2010... It says it should be under the Modify Tab in the Inquiry Panel but my Inquiry panel is nowhere to be found... I can't find any settings to recover the panel back on the to the Ribbon... wondering if anyone can tell me how to get the Inquiry panel back or simply the measuring tool...
In Revit 2010 you can locate the Measure Tool in the following location:
Modify > Inquiry > Measure
Image Example: http://screencast.com/t/xa0J6YtFx1s
If you don’t have the panel here, I would recommend resetting the user interface back to default:
Resetting the Revit Architecture 2010 user interface
If you still don’t see the panel, I would verify the technical solution below:
Thank you,
