Materials
3 REPLIES 3
174 Views, 3 Replies
Materials
Hello, I have a material that I have created that works fine if the component is horizontal but when you rotate the component the material map stays horizontal and doesnt follow the component. How do you get the material to rotate with the component?
John Fleming
3 REPLIES 3
sbrown
If you mean a hatch pattern, it must be a "model" pattern. Drafting patterns stay horizontal while model patterns rotatat with the object. If you mean a rendering material, I'm not sure.
Wotdat
How do you switch from Drafting to Model pattern?
taythebay
Open the .pat in Notepad and change the wording "DRAFTING" to "MODEL" or vise versa. If that line is not there add this to second or third line of the .pat file:
;%TYPE=MODEL;
cheers - tay
