Materials Editor Pattern Selection Bug
5 REPLIES 5
464 Views, 5 Replies
  I'm having difficulty placing a pattern type on my materials.  When I select the pattern from the list that pops up and I click "OK," the pattern selector pops back up and won't let me exit.  I think that if I go back to my original pattern, it will go away.  I've tried restarting Revit and various other matierals in other projects on different types of families in both the surface and cut pattern prompts.
  Is this a 2013 bug?  How do I chage my patterns?
5 REPLIES 5
kathryn.langan
Hi Mandy,
Do you have UR2 installed for Revit 2013?
Update Release 2 Available for Revit 2013 Products
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
in reply to: kathryn.langan
I do indeed have that.  I thought for some reason this was happening on another workstation here, but it's not--just me.  I've restarted the computer, restarted Revit and reopened a number of different projects and it's still happening.
Do you have any other suggestions here?  We've been delaying our 2014 upgrade, but maybe that will be my only solution.  Unfortunately, I'll likely need hatches before that time.
i have the same problem,  Has anyone figured out how to fix this?
Not a word.  😞
