I would like to make a vertical sun shade have transparency of 25%. In effect it is translucent. When I do this, I loose the ability for the material to cast a shadow. I am not rendering this, only using the constant colors option. Can this be done and if so, how?
Solved by Lance.Coffey. Go to Solution.
I found the following thread discussing this:
http://forums.augi.com/showthread.php?113482-transparent-massing-casting-shadows
Currently, if there is transparency applied to an element, it does not cast shadows in plan views (although it will cast shadows when rendered).
Apparently it is still the case in 2016. 1% transparency and zero shadow in Hidden or Shade visual style.
