Material to the face of a element using the paint tool
3 REPLIES 3
tonkata
1549 Views, 3 Replies
I have placed a material on a split surface using the paint tool. Is there a way to find out what material it was that I’ve used?
3 REPLIES 3
maciejwypych
in reply to: tonkata
Use material tag with Name Label.
maciejwypych
in reply to: maciejwypych
Thinking about a bit more, you can also do a material takeoff schedule with Material: As Paint filter added, to show all painted materials you've added this way.
ChrisNeedhamNZ
A quicker and easier way is to just use the paint tool again, hover over the painted surface, and the tooltip will tell you what it is painted with.
Chris Needham
Whangarei
New Zealand
