Material to Arrays - Per Item.
0 REPLIES 0
Message 1 of 1
damo3
338 Views, 0 Replies
I would like to know if it is possible to assign a different material to each element contained within an array set?
Lets use an example to help us discuss. A shelf unit family has an arrayed set of shelves within it, the number of shelves controlled by a parameter.
The family has material parameters for carcass and for the shelves, however as it currently stands, the material applies to all of the shelves.
I would like each shelf to have a seperate material whilst maintaing the array. Possible? hmmmm...
Any and all help would be appreciated, thanks.
________________________________________________________________________________
If you find posts have solved your problem, please don't forget to mark them as 'SOLVED' to help others with similar questions. - Thank you.
__________________________________________________________________________________
0 REPLIES 0
