Material differences
4 REPLIES 4
GHASEM_ARIYANI
309 Views, 4 Replies
HI All
Want to ask a question, maybe does not matter.
Window materials, materials are divided into two categories:
1-Autodesk Physical Assets
2-Apperance Library
What exactly are the differences?
Please reply if you have a convincing tell us.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
4 REPLIES 4
AJA14
in reply to: GHASEM_ARIYANI
Actually Materials is divided into 2 areas, material editor and material assets.
Each material has 4 assets: Graphics (Default for all materials containing cut and surface pattern and shaded colour)
Appearance (For rendering)
Physical (For Structural Properties)
Thermal (For MEP Properties)
The same asset may be applied to different materials (An asset is an external set of properties that may be added to any material).
Hope this helps.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
GHASEM_ARIYANI
in reply to: AJA14
HI
Thanks for your answer.
So if you want to view, structural and MEP and Architecture.
When I need to render All they have to do with material Appearance.
If you would like to analyze the structure, the materials I use Physical This means they have to re-change materials.
AJA14
No you don't. Every material in the material editor can contain 4 material assets (graphics by default) and the other 3 are optional. So you can have all 4 assets for one single material.
Ali Al-Hammoud
hi
ok
I did not consider this point
Thank you
