Material Cost
1 REPLY 1
250 Views, 1 Reply
Material Cost
How does the Cost parameter in materials work in Revit?  I know you can set a value for a cost.  But what amount of that material is the cost associated with? For example, if I set a cost 3.00 for Common Brick, is that 3.00/unit, 3.00/sq. ft., etc?
Thanks!
Tags (3)
1 REPLY 1
GHASEM_ARIYANI
hi
Please go to the following link Download the tutorials.
Using Schedules for Material Cost Estimation in Revit
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
