Revit Architecture
Active Member
funnydean62
Message 1 of 2 (127 Views)
Masses vs. Walls
127 Views, 1 Replies
08-31-2012 09:58 AM
I'm trying to build a wall that has the concrete block pattern that's offset by 1/2.  If I build a wall using mass then I can make it into a pattern that I want but then I can't paint it so that's it's clear or see through.  On the other hand if I build a wall just using the walls then I can't find an option for the block pattern.
Thots?
Maybe I'm just secretly blonde.... LOL
*Expert Elite*
LisaDrago
Message 2 of 2 (93 Views)
Re: Masses vs. Walls
09-04-2012 06:26 AM in reply to: funnydean62
Okay - what do you mean by offset by 1/2?
and attached is an image on where to place the surface pattern. in the materials you can specify the surface pattern.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
