I'm trying to build a wall that has the concrete block pattern that's offset by 1/2. If I build a wall using mass then I can make it into a pattern that I want but then I can't paint it so that's it's clear or see through. On the other hand if I build a wall just using the walls then I can't find an option for the block pattern.
Thots?
Maybe I'm just secretly blonde.... LOL
Okay - what do you mean by offset by 1/2?
and attached is an image on where to place the surface pattern. in the materials you can specify the surface pattern.
LD
