Revit Architecture
Valued Mentor
gh_ar
Message 1 of 7 (373 Views)
Accepted Solution
Mass Error
373 Views, 6 Replies
09-15-2013 09:07 AM
Hi
I now Ceiling Design like the image below.
To do this The Mass And Adaptive Component used.
But when Adaptive Component I enter Mass.
And  I on the places Repeat until the tool To use I encounter the following warning.
How do I solve this problem Or If you have a better method. Do you mind.
Please help me!
Revit files Attached below is.
Continuing your Idea of an array I would turn from array of Solid Forms to array of Voids, as follows:
  1. Load the Ceiling Design.rfa as a mass into a Project
  2. Apply a by face comand - I used roof - so : Architecture >Roof>Roof by Face (make a roof of a thicknes equal with the height desired for the ribs)
  3. In a plan view : Architecture > Component >Model in Place - make a rectangle and extrude it so to be higher than the roof - Create Form >Void Form
  4. Create an array of Voids - the distance between them being equal with the width of the ribs
  5. Select the Roof and then the Voids - Cut - you will obtain a row of ribs that can easely modified in width and height
Valued Mentor
gh_ar
Message 2 of 7 (311 Views)
Re: Mass Error
09-16-2013 10:02 AM in reply to: gh_ar
hi
Please someone help The warning I solve.
*Expert Elite*
constantin.stroescu
Message 3 of 7 (290 Views)
Re: Mass Error
09-16-2013 11:45 PM in reply to: gh_ar
A method could be to work in X-Ray mood and to make sweeps along the edges....but it is not an automatic way of doing .You have to do them one by one...
  1. Turn off U and V Grids
  2. Activate X-Ray
  3. Add Profil
  4. Select one profil
  5. Insert a Reference Point on the profil
  6. change the Work Plane to Host>Form Element by clicking the point - Set
  7. draw a rectangle on this plane ,placed on a central position (use Viewer)
  8. select the profil and the rectangle (using CTRL) and Create Form...a sweep will be created
  9. select the rectangle shape and Copy (on clipboard)
  10. select another Profil , place a Reference Point, change the Work Plane to the point's plane and Paste the rectangle - make another sweep
  11. and so you can contue till the end
I have to confess that the method does not excite me too much...you have to repeat this operation many times and if you have many ribs it will be quite difficult.....
Constantin Stroescu
BIM Manager AGD
Valued Mentor
gh_ar
Message 4 of 7 (268 Views)
Re: Mass Error
09-17-2013 11:02 AM in reply to: constantin.stroescu
Hi
thanks for you.
Valued Mentor
gh_ar
Message 5 of 7 (240 Views)
Re: Mass Error
09-18-2013 01:33 AM in reply to: constantin.stroescu
Hi
I use The Family
metric Generic model In this case, 've Created.
I used Tools:
Ref Plane-Sweep-Array-Revolve And Extrusion Void.
Do this is a good way?
thanks
*Expert Elite*
constantin.stroescu
Message 6 of 7 (214 Views)
Re: Mass Error
09-18-2013 11:10 AM in reply to: gh_ar
Constantin Stroescu
BIM Manager AGD
Valued Mentor
gh_ar
Message 7 of 7 (184 Views)
Re: Mass Error
09-20-2013 02:05 AM in reply to: constantin.stroescu
Thank you
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
