Hi
I now Ceiling Design like the image below.
To do this The Mass And Adaptive Component used.
But when Adaptive Component I enter Mass.
And I on the places Repeat until the tool To use I encounter the following warning.
How do I solve this problem Or If you have a better method. Do you mind.
Please help me!
Revit files Attached below is.
Solved by constantin.stroescu. Go to Solution.
hi
Please someone help The warning I solve.
A method could be to work in X-Ray mood and to make sweeps along the edges....but it is not an automatic way of doing .You have to do them one by one...
I have to confess that the method does not excite me too much...you have to repeat this operation many times and if you have many ribs it will be quite difficult.....
Your Name
Hi
thanks for you.
Hi
I use The Family
metric Generic model In this case, 've Created.
I used Tools:
Ref Plane-Sweep-Array-Revolve And Extrusion Void.
Do this is a good way?
thanks
Continuing your Idea of an array I would turn from array of Solid Forms to array of Voids, as follows:
Your Name
Thank you
