Masonry Openings
5 REPLIES 5
tbroom
408 Views, 5 Replies
Masonry Openings
How can I place a window in a masonry wall and have a masonry opening that is larger than the size window?
Thad Broom, AIA
5 REPLIES 5
melarch
in reply to: tbroom
You have to create an additional cut in the Window family to have it cut the wall back on either side fo the window opening. Time to learn to work with families. You could also create an in-place Void set to the Wall category and use the Cut Geometry tool button to cut a brick return out of the wall for each window, but this would have to be done for each and every window, so it would be easier and more efficient to develop the cut/void in the window family directly.
Mel Persin, aia Edited by: melarch@comcast.net on Apr 9, 2009 7:55 AM
melarch
in reply to: tbroom
You have to create an additoinal cut in the Window family to have it cut the wall back on either side fo the window opening. Time to learn to work with families. You could also create an in-place Void set to the Wall category and use the Cut Geometry tool button to cut a brick return out of the wall for each window, but this would have to be done for each and every window, so it would be easier and more efficient to develop the cut/void in the window family directly.
Mel Persin, aia
tbroom
in reply to: tbroom
Thanks, Mel. I will try that. I tried making my own window family where I changed the opening parameters to masonry openings and added new ones for the actual window but this is awkward.
Thad Broom
tbroom
in reply to: tbroom
Mel, I tried to put a void extrusion in the wall of the window family but can't do it. How do I do what you suggested?
Thad Broom, AIA
tbroom
in reply to: tbroom
OK, figured it out Mel. That works perfectly. Thanks a lot.
Thad Broom, AIA
