I've been trying to create a repeating detail component to try and replicate my AutoCAD line types. We have a lot of utilities line types, water, gas, elec etc that we need to re-create in Revit!
I can create the text in a detailed family template easily enough, however I want to mask the "text" with a background and cannot get it to work.
Is there a way I can add a masking background to my repeating detail?
Solved by Alisder.Brown. Go to Solution.
The repeating component is a AutoCAD import of some text. I have tried Revit text but that does not work.
I have followed a guide up to a point, but now that Revit does not allow you to create a region (hatch) with no pattern I cannot get my repeating pattern to have an opaque background.
I am using Metric Generic Model Pattern Based.rvt template.
TrevN
If i understand correct, this the type of thing you are looking for? Or along theese lines (See attached family)
It is a detail component with editable text, spacing, start/end offsets and backround border size.
Down side to this is you will need to manually change the size of the border if you have large words, or smaller/bigger text. (It also scales with the view scale so might need some manual manipulation if used in different views with various scales)
Hope this helps
AJA14, the family you speak of that can be downloaded online, I think I have that and i just posted a problem I am experiencing with it, perhaps you know? The problem is, the text has opaque background which is supposed to conceal the line behind it, which in Revit, it does. But when printed to PDF... the line can be seen a strikes through the text. Know why by chance?
ah nevermind, just worked it out. The nested text needs to be changed to 'shared'. effects size, but thats ok.
AJA14,
I can follow your 6 points and I can see that the Detail has come into my project however, when I try and make a repeating pattern the detail does not appear!
I have tried to create a new repeating pattern and replace the detail in an existing pattern that works but the new detail never appears?
Any ideas?
Attached.
All it should look like is:
--------S&T---------S&T---------S&T---------
Thanks for your help.
This?
You will need to change the size of the border using the instance parameters but it works how you want i think. (You may want to change the line type and text size)
Annotate > Detail component > "family"
Its a line based detail item, you can make any changes via the instance parameters
Hope this helps
alisder,
This does work great but I want to change the text from S&T to something else. Everytime I try it says there are errors.
I'm not sure how you created the array link to correct this?
Cheers
Strange, it works fine for me... see attached.
Place the line in the project, select it, and change the instance property for "Sys Text" to whatever you want. It shoudl work, i tried it on a few machines and works on every one.
When exactly, and what are the errors you are getting? What are you doing precicely?
Or are you trying to recreate the family yourself?
Sorry should have made that a bit clearer!
Yes, works fine in a project but what I would like to do is create a new family and change the text so it doesn't come out as S&T everytime.
When I try and change the sys text from S&T I get error messages and constraints.
Being new to revit and not quite seeing how you created the family in the first place I think I'm missing something!
Again thanks for the help.
Ah okay
So, when you are in the family, you want to change the parameter value for the "Sys Text". To do this, follow theese steps:
I just ran through this process and works fine.
Hope this helps
