Hi, I have computer at work and another at home that I use to work on revit projects. I typically work on a project between the two locations, just transferring the rvt file on a USB stick. Just recently, I've come across issues in managing materials, and families where I've created new ones and they haven't transferred with the rvt file to the alternate location. What's best practice in managing materials, families, etc. between two locations?
thanks
- Mick
Solved by constantin.stroescu. Go to Solution.
try these:
The best way , in my oppinion , is to place the file in cloud (I use Dropbox) - and so you'll can keep the file in the same location , no matter you are at office or at home.....
Your Name
2. then , when : Open - you will have on the left side shortcuts to your selected Places. Click on a shortcut and the location will open imediately:
Your Name
