Making object invisible in walkthroughs
1 REPLY 1
bng918
288 Views, 1 Reply
Hi all
I want to make a walkthrough of the building I have created, and I was going to have the camera walking down the hall, with the camera aimed to the side so that you can see into each room as you pass it.
However, the doors are in the way. Is there a way to make the doors invisble in the walkthrough (or open them or something) so that it just looks like an arch-way.
Thank you for any advice
1 REPLY 1
LisaDrago
in reply to: bng918
Have you tried turning your doors off under visibility graphics (VV or VG)? It will turn the whole door off but you will be left with an opening.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
