I apologize if this has been previously discussed but i was wondering where i might find some info regarding converting Revit files to stl. or obj. and how the 3D printing is generally working out, we're considering the Makerbot Replicator (5th Generation) but would like to see or hear from others how its going, thank you very much.
Dallas
Solved by loboarch. Go to Solution.
Thanks Lobo,
Yeah we're not looking to produce detailed items, some site work with some low level detail. Since we dont have Inventor, i'll look into the add-on, is that available on the Autodesk website?
I have been trying to get my Makerbot Replicator 5th Generation to print from Revit for about a year. Before that, I was trying to get Revit to print to the Replicator 2 as well as a RepRap that I built. I have used Cura, Slicer, and several other slicing software. I finally succeeded in getting the foundation to print smoothly with the Makerbot 5th Gen. However, on all the printers the walls are poor quality. If printed at a small scale, with thin walls, the model prints O.K. If the walls are thickened, then they become "wavy" or "rippled" as one person put it. I have sent the gcode file through a viewer at gcode.ws. This is a free viewer to see the tool path movements. Herein, lies the problem. If you scroll on the slicer height, then you can see the wavy tool path movement within the walls. Also, the walls are 3 individual lines suggesting that they are solid. I tried using MeshMixer to hollow out the model, but got no results. I even tried making it solid in Meshmixer, but still got "ripples" in the walls. I have also tried Netfabb and Cadspan, which is the best for STL repair. In order to confirm the STL file was good, there is a viewer called "minimagics" by Materialize that you can verify the mode. I am exhausted at this point and have no direction to go now. I wish Autodesk would get involved. The guys at Makerbot are good and helpful, but aren't familiar with Autodesk products. Any suggestions???
Anyone feel free to contact me if you wish to discuss this issue.
Robert Cummings
(713) 550-7331(713) 550-7331
rc@cummingsdevelopment.com
