I am project coordinator on a work sharing project. As such I am responsible for family creation and Project Standards and need to have these items editable. I can select them all and make them editable but they always get changed back to none editable? How do I check these out until I relinquish them?
Solved by ryan.duell. Go to Solution.
You should be able to set any of the Project Standards worksets editable and maintain ownership until you synchronize with central. Or you can set them editable > Synchronize and Modify Settings > un-check “After synchronizing, relinquish the following worksets and elements” > “Project Standard Worksets”.
Also here is some additional information regarding the Project Info workset:
Thank you,
What is the point of the Project Standards Worksets?
In my testing, if I lock them down by taking and not relinquishing ownership, it prevents other users from modifying the types and styles which existed at the time I lock them down, but doesn't stop other users from polluting the project by creating a plethora of non-standard new styles and types.
- Rusty Gesner
