Revit Architecture
Member
1057583
Message 1 of 5 (503 Views)
Louvre family not showing up in elevation
503 Views, 4 Replies
08-16-2012 02:38 AM
Hi. My concern is regarding a louvre family i am placing on walls in a multi-storey commercial project. They are viewable in 3d mode and Floor plan view but when i switch to elevation, all i get are holes in the walls where the louvre should be sitting. Any help would be an appreciated. This louvre family is from Breezway and i am getting the same result with all Breezway family members i have downloaded.
Shandor Fahrenfort
sfahrenfort@hotmail.com
The family has the louvers set to not display at course level of detail.  if you change the detail level of the view the louvers will show up.
Employee
loboarch
Message 2 of 5 (487 Views)
Re: Louvre family not showing up in elevation
08-16-2012 06:45 AM in reply to: 1057583
Looks like there is a bad visibility setting in the family.  Post the RFA file so someone can take a closer look.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Member
1057583
Message 3 of 5 (466 Views)
08-16-2012 09:04 PM in reply to: loboarch
These are the louver family files I am using with Revit 2012. If there is a fix please let me know it in case I come across the problem again. Thanks.
Employee
loboarch
Message 4 of 5 (443 Views)
08-17-2012 11:15 AM in reply to: 1057583
Jeff Hanson
Member
1057583
Message 5 of 5 (423 Views)
08-18-2012 04:24 AM in reply to: loboarch
Thanks alot. That fixed it :smileyhappy:
