Revit Architecture
Active Member
rtcorpuz
Message 1 of 3 (95 Views)
Lot Technical Data
95 Views, 2 Replies
08-23-2004 01:47 AM
Would it possible to create a table or schedule for technical description of the lot? From what I read from help, I can only create a schedule of area of lots. I need this in some of my project that requires a technical description of a lot.
*Aaron Rumple
Message 2 of 3 (95 Views)
Re: Lot Technical Data
08-23-2004 06:01 AM in reply to: rtcorpuz
You can add whatever data you want using shared parameters. Do you have an example...? "rtcorpuz" wrote in message news:673733.1093250856055.JavaMail.jive@jiveforum2.autodesk.com... > Would it possible to create a table or schedule for technical description of the lot? From what I read from help, I can only create a schedule of area of lots. I need this in some of my project that requires a technical description of a lot.
Active Member
rtcorpuz
Message 3 of 3 (95 Views)
08-23-2004 07:32 PM in reply to: rtcorpuz
Thanks for your response, I think I already get the answer. For the benefit of others, what I am looking before is the DEED DATA TABLE. At first I thought I could find it under the "Property lines" Category, upon further exploring revit, I found it under "PROPERTY LINE SEGMENTS" Category.
Revit is really a good stuff software.....
Thanks again!!!!!
