Dears,
I have created a line based revit family that I am nesting in other family. The family consists of several trusses that need to be arrayed and rotated (basically a tower crane jib). The family works well and rotates well, but I need to FIX it's origin so that it always rotates around the same origin as it suddenly moves from the origin while I flex the family several times.
Note: I am trying to module a tower crane Jib that can be arrayed and rotated and the length and width of its module be changed. My approach was to create a parametric module (one unit) then nested that into a line based family so that I can array it there and give it a rotation parameter, then nested that to the main family host. I will appreciate any other tips or approaches to achieve my goal in other ways
Regards
Rotating objects in Revit is normally done with nested work plane based families attached to Reference Lines (not Planes).
A site that helped me a lot can be found HERE.
It explains how to rotate objects around three axis (but can of course be limited to one)
Louis
Please mention Revit version, especially when uploading Revit files.
